SOURCE: Smeg main oven failure
problem is almost certainly the circular element. these sometimes fail with obvious damage but not always. check continuity across the element to be sure. you are right about element fixing. there is no reason why the design should'nt allow removal from the front as many do but i suppose the guys who make these things don't have to fix them.
SOURCE: Oven doesn't heat up
Problem is caused by out of calibration main oven thermostat or faulty (melted) function switch, only sollution check function switch for signs of melted or burnt connection other wise change stat. Regards Engineer
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
SOURCE: top oven grill element
Hey there, Shouldn't be too difficult. Just two nuts to remove. If unsure about reconnecting wiring, draw yourself a little diagram clearly indicating the colours. Let me know if you are having further problems.
