Nokia N95 Cellular Phone Logo
Posted on Mar 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Repair a black line appearing on the screen nokia 6600 i have a black line across my screen it won't go away. it hasn't been dropped or been wet.It definatey not cracked please help with thanks Emma
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Mar 22, 2008
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
24062
Points
176
Ur screen is damaged dear may be in u\ur pocket try to readjust creen conector may be it works otherwie go to change it
4helpful
Hi, im 14 and i got a Panasonic Lumix DMC-F3 camera for christmas and have had it for about 4 months, a few weeks ago a 1cm black dot appeared on the screen. It doesnt get bigger when i zoom in and doesnt...
This is a faulty or damaged LCD screen. The fact that the pattern of dots and lines is unchanged by zooming and appears on the menu screen confirms it.
The LCD cannot be repaired, it must be replaced. As long as the fault is not due to misuse (such as being impacted or dropped or getting the camera wet) then the damage is covered by the manufacturer's warranty. Contact Panasonic in your country to arrange a free warranty repair; they will normally require proof of purchase and will check the camera to look for evidence of misuse when they receive your camera. If they find any then the repair becomes chargeable.
I hope that my speedy and free reply has been of use to you; please take a moment to rate my answer.
4helpful
My KDL46X3100 has developed two thin black lines
It is problem of LCD Panel that will be replaced.
Please check with dealer / store for extended warranty option.
1helpful
Black lines across the screen
Black lines across the screen generally means that the pixels on the screen itself have gone bad, or the contacts/processor chip has a broken connection. Either way, its an issue that requires repair.
Diagonal black line appearing in the pic bottom 1/3 of screen when this does not appear white burnt out line appears in centre of screen all this appears in the pics on the memory card mostly the black...
Try formatting the memory card in the computer then format it again in the camera and see if that clears the problem. Also try another memory card but if the problem persists it probably needs a repair.
Black line across screen nokia n95 8gb
Completely switch off and remove the battery and again switch on.........If it not works then there may bea display problem and you need to change the display.
rate this if it is useful.
NOKIA 6600 display
you need to open your unit and clean the connection from the lcd to the board of your phone. be careful not to damage some wire of the connector.
Nov 20, 2008 • Nokia 6600
Black line across display screen
Beyond repair I would imagine - these thing cannot usuaslly be repaired in these circumstances.
1helpful
4answers
Repair
service the display
Sep 23, 2007 • Nokia 6600
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
