How to format 2700classic?
Hello
Go to Apps on your phone, select options and you would see the format mem. card option.
Best regards
not the memory card..the phone it self..how to reformat the phone memory?
nokia
bro, Whenever i plug in this phone to pc ... it's says unknown file format on memory card.. plz Help ;P'
Jst ********
Please send me nokia 2700 classic factory reset security code 12345 is wrong code by my mobile
Buan ziua am un nokia 2700 clasic .. pun card de micro sd .. si imi spune c anu e format .. am dat format .. cnd este in desfasurare spune opreatiune esuata.. am pus si pe calc si am formatat carrdu da tot nu il recunoaste pe telefon .. cnd pun cardu spune card not formating .. ii dau format imi da eroare operation .. c sa fac .. are cineva vro ideie ..
SOURCE: nokia 2700 classic phone :if i enter into radio or
You must have to delete some unnecessary file from your Nokia 2700's phone memory.
After deleting some file from phone memory it will work fine 100%.
Thanks.
(If my opinion is helpful for you please leave positive feedback for me.)
SOURCE: Classic 2700 Cell Phone: how to lock memory card and smses in nokia 2700...
I am unable to tansfer msgs from phone memory to my moemory card. I have tried hard a no of suggestions but still not got a useful for me.
Plz help me out from this problem.
Mahi
SOURCE: Phone Nokia 2700 Classic remove
Hi ,
Follow the following steps to remove the password check in memory card
It has worked for the following user . pls click here to view
For any quires write back to me .If yo are satisfied with my answer please vote for me(4ups) . thanks in advance
SOURCE: i need to master reset
To hard reset your Nokia 2700 Classic you just have to press *#7370# and press Dial. The phone will request the security code that is by default 12345. Please be aware that you will loose all the data in your phone, so you should backup all relevant information.
If you want to soft reset your Nokia 2700 Classic you need to press *#7780# and then Dial. The security code is 12345. Once you complete this, your phone will come back to factory settings, but you will not loose personal data.
Happy holidays!
SOURCE: nokia 2700 classic with 1GB memory, ''operation failed''
Dear Big Brother.
Problem One.Nokia 2700c Model Mobile Memoryte Asle Sudo Opening Gallery Bar Bar Scan Kora.Or Operation Filed Ase.
How do i stop invalid setting in my phone nokia 2700 classic?
