Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser. * Loose wire connection between the machine control board and the dispenser motor * Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it.
Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!!
Happy fixing!!
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
