You need to replace ( or have it replaced ) , the thermostat . The piece the knob pushes onto . The liquid is seperated inside the thermostat cap tube , causing the internal contact not to close . Also , a tap on the knob , will start the refrig , until it reaches temp , but then may not restart until another tap . Replace it and that will solve the problem .
Testimonial: "thank you "
Once your refrigerator achieves the temperature set by you, it stops working and will start working only after some time when the temperature again increases. This is a power saving technique. Just keep the temperature knob undisturbed and observe your refrigerator. You will understand it then.
SOURCE: my refrigerator is freezing everyting
ur temprature knob is not adjusted so u have to read the manual ok.read it and adjust it
