SOURCE: printing blank pages
My printer has funn ink cartridges and it is printing blank pages and it is saying that the ink is empty. Please help
SOURCE: Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
SOURCE: HP photosmart 7150 - looks like it's printing - pages blank
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: the printer acts like it is printing, but doesnt actually print
uninstall ur printers driver and re-install it. This will deffinetly solve your problem but then also giving u a word of caution repair your windows Operating system. Its easy just put ur cd and do whatever it asks until repair comes and put it on repair option. your spool.exe is corrupt by virus
SOURCE: The printer is printing blank pages.
STEP 1: Disconnect and Reconnect the Printer Power Supply
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
STEP 2: Run a nozzle clean on the Dell A940 inkjet printer.
To run a nozzle clean, perform the following steps:
1. Click the Start button, point to All Programs, point to Dell Printers, point to Dell AIO Printer A940, and then click Dell Printer Solution Center.
The Dell Printer Solution Center menu appears.
2. Click the Maintenance button.
The Maintenance window appears.
3. Click the Clean to fix horizontal streaks button.
4. Click the Print button.
The Nozzle Clean function prints a page.
5. Check the Nozzle Clean Printout to verify that it is free of defects and that all expected color bars exist on the page
STEP 3: Restore the printer settings to factory default
To restore the printer settings to factory default, perform the following steps:
1. Click the Start button, and then click Control Panel.
2. Click Printers and Other Hardware.
3. Click Printers and Faxes.
4. Right-click the Dell Printer icon, and then left-click Properties.
5. Click Printing Preferences.
6. Click to select Save Settings.
7. Under Restore, click Factory Settings (Defaults).
STEP 4: Clean the Contacts and Wick the Ink Cartridge
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
1. Ensure the printer is powered on.
2. Lift the scanner unit.
3. Open the cartridge latches and remove the cartridges from the carrier.
4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Note: Never wipe the cartridges from side to side, as this causes cross-contamination in color cartridges.
Cleaning the Contacts
1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
2. Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible.
Note: Do not use the same cloth that was used to clean the cartridge nozzles. This may cause more contamination on the cartridge.
3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
4. Replace the cartridges in the carrier and close the scanner unit.
5. Print the document again.
6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Then run again STEP 2. If the printer still prints in blank pages, contact Dell Technical Support. They may need to replace the Ink Cartridges.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
