I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player hooked up correctly to record automatically. HELP
  • jawtexas2 Apr 19, 2010
    the problem is that the cable box serves 2 tv's. the manual shows to connect cable line to vcr in then out to cable box in. this will not work since the box serves the 2 tv's.
  • 1,768 Answers
1.I will need the connection that on the TV and what Time Warner cable box you are using.
2.check all cables and connections to the TV and the cable box
3 you could have the TV in another mode. check the remote settings
Posted on Apr 19, 2010
  • 11,896 Answers
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
  • Nate Stansfield
    Nate Stansfield Apr 19, 2010
    Cable box, to VCR IN, then a cable from VCR OUT to TV IN. That is how I have mine set up and I also run two tv's on one cable box.
SOURCE:
How to hook up vcr and tv using digital adapter
You can hook up the VCR directly to the TV; you don't need to hook up the VCR to the adapter. If you already had the VCR hooked up to the TV, you don't need to change those connections.
Jan 29, 2015 | Televison & Video
How do i hook up my new cable box for descrambling to my vcr
If the cable box has audio and video outputs on it then use RCA type cables to connect the outputs of the cable box into the video and audio IN of the back of the VCR. Then select L1 on the VCR. If your TV has video and audio input connectors connect another set of cables form the VCR OUT to the IN puts of the TV, then select the AV inputs on the TV. If your TV doesn't have video and audio inputs, then use a coax cable from the RF/Antenna OUT of the VCR and connect it to the antenna jack on the TV. Now select 3or4 on the VCR to whatever works for your location and tune the TV to that same channel. That's it ...you now can watch and record the channel you're watching. You will have to have the VCR powered up all the time to watch TV
Jul 28, 2017 | Symphonic SL260A S-VHS VCR
How to use the video source to watch a movie when i have time warner cable service
are you talking about VCR / DVD or DVR source. for VCR or DVD your connection shall be for VCR, cable out from the TW box to VCR in and VCR out to TV (VCR ch selector and TV must be set to ch 3)......... DVD connection out from DVD to TV's yellow/white/red (digital in on TV), to view dvd using remote change source to the digital source (av1 or av2)... for the DVR you must call TW to make sure your box is set up to record and view....
May 07, 2011 | Televison & Video
I have a JVC VCR and a Samsung 22" TV. I lost the VCRE manuel between moves and don't know how to hook it up! I also have a cable box.
hi there
ok here i go male plug in the tv female plug in the vcr
from you cable box you have 3 cable 1 go tv room tv
two go two you vcr and 3 go to your room tv
if yo dont came right email me on info@jvcomp.co.za
Dec 14, 2009 | JVC DR-MV7S DVD Recorder/VCR
How to connect a Time warner cable remote to the tv
I made mine work by using programing the vcr button as opposed to the tv.
Aug 21, 2008 | Sylvania 6520FDE 20 in. TV/DVD Combo
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/shannon_b38635e8878032de
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Problem dubbing VCR - DVD
I have 3 of these machines. I do not think it likes theRW disc's. Two of my machines are 4X & one is 8X. I have very great success with 4X DVD-R & 8X DVD-R disc's. I hear they have a fix for upgrading to 8X speed. Here is the link with the information:
http://www.videohelp.com/dvdplayers/symphonic-sr90ve/4861
You can still buy the 8X speed disc's on the internet. Hope you can get the machine to work, because I love the ones I have.
Feb 23, 2008 | Symphonic SR90VE
Dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Jan 16, 2008 | Samsung DVD-V3500 DVD Player/VCR
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Can't find a channel to watch a DVD pre-recorded DVD
you should have a input select button on your remote. video 1 should be the front and video 2 should be the back. i had to buy 3 or 4 different universal remotes when mine messed up just to get the one button to change to change it to the inputs because there is no other way to change it to that with he buttons on the tv. kinda surprised that you didn't try and push that button yet.
Aug 31, 2007 | Televison & Video
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
