Panasonic Lumix DMC-TZ1 Digital Camera Logo
Posted on Apr 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you turn the flash off so I can take pictures where a flash cannot be used?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Panasonic Master 102,366 Answers
  • Posted on Apr 19, 2010
Panasonic Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442618
Points
622693
Press Right on the cursor button (marked with the lightning bolt icon) to switch the flash setting. Your choices are AUTO, AUTO/Red-eye reduction, Forced ON, Forced ON/Red-eye reduction, Slow sync/Red-eye reduction, and Forced OFF.
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
2answers
While trying to take pictures of my son's Friday night football games, the pictures come out super dark when I use the flash. If I turn the flash off, the pictures are light, but all blurry. How can I fix...
The flash is only good up to 10 feet....are you that close? If not, turn off the flash and turn up the ISO to make the camera more sensitive to the lower light levels.
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
BLURRED PICTURE WHEN USING MOUNTED FLASH.
If you are not using canon lenses then the low light focusing aid will not work correctly. Go into the menu and turn of the flash infra red light
1helpful
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
