Most of the time after the wep has been set you are not able to view the wep keys without knowing the keyword you used to genrate them a handy method for getting around this is resetting the router to its manufacturer defaults and reconfiguring it using the default gateway ip address this is done by using a pin and pushing a small button usually located on the rear of the router after doing that hook it up after restarting your modem and computer right click your connection icon in the lower right corner and click properties or network sharing center from there right click your connection and find your default gateway look for the number sequence after the default gateway and type that number into your internet explorers address bar it should prompt your for a username and password by default it is admin admin or admin password this should bring you to your routers settings and enabling wep should be under your wireless security settings
hope this helped
please leave feedback
thanks
Robb
