When I have my Epiphone BB King Lucille guitar plugged into the Mono Jack, the bridge pickup does not work, is it supposed to work or only work when both the mono and stereo jacks are plugged? Is there a stereo cable made for this guitar?
Realize that when you plug into the one jack it disconnects the fingerboard pickup from the mix.
DO NOT USE "stereo" cables as it is intended to use TWO MONO cables, one for each side of the stereo.
IF you plug into the one jack that will connect to the bridge pickup, it will disconnect the fingerboard pickup from the mix BUT leave the fingerboard on its own jack.
That same jack will have BOTH fingerboard and bridge pickups IF the second jack (bridge) is not plugged into.
This is according to the schematic. If you find that yours works backwards, then either the schematic is wrong OR your guitar pickups may be electrically swapped.
The pickup when turned up loud on the preamp
explain how to use the TP-6 fine tuning bridge on the Epiphone B.B. King Lucille guitar
