1996 Toyota Previa Logo
Posted on Apr 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I own Toyota Emina Estima TD permanent
Hi, I own Toyota Emina Estima TD permanent 4WD model 1996. I'm encountering problem on the power or transmission gear train. Just recently, I replaced the front transmission transfer case after it broke due to still unknown reason. After the replacement of the broken case I am still encountering the same problem of the transmission or power train that seems to be locking while on acceleration or deceleration with metal grumbling noise. I sense that if I continue on using the vehicle it again will break the front transfer case if not already broken.
Please help me on this problem.
Thanks for your concern.
Anonymous
Level 2:
New Friend:
  • Expert 49 Answers
  • Posted on Apr 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
49
Questions
0
Helped
17027
Points
146
There may be more to it.. Transmission- P.T.O(Front wheels)-Rear Differential(Rear wheels). Or may have Transmission-Transfercase drives front differential(Front wheels) and rear differential(Rear wheels). So if one was rebuilt there should still be another that is still the root of the problem. Find out what exactly was rebuilt.
How do I fix reverse gear on Toyota estima emina automatic
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
I am doing an oil change on my toyota estima 2.4 Petrol Year 2000. i need to know the engine oil capacity ? Pls help..
I have toyota emina,diesel engine, i change oil every reaching 5000 kilomters on guage, with 6 liters diesel engine oil.
My 4wd toyota Estima judders when turning tightly
Hi ...it could be you need front end work ...does your vehicle have rack pinion steering ...you might have to replace it ?Or have it flushed ..any leaks ? Let me know if this was helpful to you ...might be other things too ....
Good luck Joe
1helpful
2answers
New gearbox oil
oil filler underneath passenger seat lift back carpet twist knob and remove plate youll also on some models under the bonnet have a oil reserve bottle which should be full or at least 3 quarters full -estima emina 2.2 diesel
2helpful
Toyota estima emina
Replace black button on dash board in order for it to work
8helpful
2answers
Tyre air pressure
Hi, all manufacturer place the PSI on the side of the tires. If you can not fine this in the owners manual, also there are sticker on the drivers door sill. the basic air pressure is around 32 - 35 psi.
2answers
Estima wont start
possible loose battery terminal or loose earth
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
