I have a Asko Dryer #7305 and it is shutting off using a F5 code, regardless of how small of a load (i.e one towel). Shuts off using timed or moisture program. Per manual, F5 is the moisture sensor. Where is it located, where can I buy one, and how do I replace it? Could it be something else? I have cleaned the unit thoroughly of lint and the clothes/towels have been spinned very dry prior to putting in dryer.
Hi, Based on the explaination in your post I guess the unit will operate without anything in the dryer, correct ? If that is the case if you remove the lower panel you will reveal a plastic cover over the blower housing. Located on the housing you will find the moisture sensor usually hidden under some black puddy. Remove the gum type puddy and there you will find the sensor held in place. Remove the sensor and clean it out best as you can. Re-install the moisture sensor and give it a test. If that fails to remedy the problem you may indeed require a new sensor. Let me know and I can provide you with a part number or you can visit "repairclinic.com" and enter your model number and a description of the part you need. Hope this was helpful to you. Let me know or rate my info accordingly. Thanks for visiting "fixya" today and good luck. macmarkus :)
Testimonial: "Very informative, very detailed advice. Thank you!"
Hello again,
I just read your post and it is getting quite late where I am but I will post back again tomorrow. I have the part number in my Asko literature, but am away from my home pc presently. That IS the sensor by the way, a thimble like device, that is a great description since it does resemble one closely.
I seem to recall a repair tip regarding those unit's in the late 90's early millenium when I worked for Asko but I will need to pull up my older files, please hang in there and I'll have more info asap.
Thanks again,
macmarkus :)
OK,
I pulled up the literature on your dryer and although I didn`t find any "rework" or "repair tip" material I can at least give you the values to look for to determine if the sensor is indeed faulty.
** Unplug the dryer from the wall or turn off the breaker **
Remove the leads of the sensor and with the aid of an ohmeter measuring accross the sensor should supply a reading of 40 - 60k ohms ( thousands ) at a temperature of 86°F - 68°F. ( 20°C - 30°C ). Unfortunately you must do the measuring at the integrated board to which the sensor leads are soldered to. I`ve attached the image below of what to look for.
You`ll also want to check for any wire`s which may have gotten severed from rubbing against the drum or the like. An open circuit will cause the F5 error so you want to be sure it isn`t simply a wire cut or something simple such as that.
Hope this helps move you forward, good luck.
macmarkus :)
For my Asko 7305 Dryer I removed the lower panel that has a Philip Screw on the left and on the right with a Philip Screw Driver.
I used a * head on the screw driver to remove the plastic face plate and set it aside with the two * screws. I vacuumed the face plate and all the lint that I could see with a flat extension on the vacuum cleaner hose. After that I removed the small steel plate that had 1 * screw and cleaned the first sensor and replaced both. After that I removed the two * screws to the moisture sensor and carefully pulled the black putty off and rolled it into a ball to use it again after cleaning the moisture sensor and replacing the two * screws. After replacing all of the above I tested the dryer with two knee length wool socks on low temp. All worked fine for 10 minutes. After that I placed two flannel shirts in for 15 minutes. All worked fine. End of Report
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Macmarkus...yes, it will operate with nothing in the dryer. I did find a small mesh thimble shaped object with wires behind black putty in the location you mentioned. Is this the moisture sensor? I cleaned/blew it out with a air compressor, but still getting the code. Could you tell me the part number? Is there any way I could make sure this is the problem before investing in a new sensor?
Thank you very much! I know that the sensors are very expensive, and I wanted to make sure by testing and you helped me greatly. I only cleaned out the mesh thimble...I never checked the board. Hopefully the problem is there and can be an easy remedy. Thanks again!
