Have a badger garbage disposal. I used the reset button and the motor will run but the blades are not turning. Also when the diswasher is draining, water comes up through the garbage disposal is that normal?
Sound's like you have a problem with your drain pipe's. it is not normal for water to come back up.check the allen key bolt, located on the bottom of unit .insert allen wrench /key,and turn in a clock wise&counter clockwise motion to see if disposal is jammed.you also might consider some drain opener before it get's worse
Testimonial: "Thanks for the info. Unjammed it like you stated and used drain opener. Walah, it worked!"
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
d
