Does the lens assembly extend from the face of the camera? The mechanism for the shutter may be stripped or possibly just derailed. Can you move the shutter out of the way manually? Try a very delicate touch and see if the shutters will pivot out of the way of the lens path. Use a small implement. If the shutter moves easily, it is most likely a damaged mechanism. You can move them out of the way and secure them, at least your camera will work. The cost for repair is probably not worth it, but if it can be made usable, then it is worth keeping.Does the lens assembly extend from the face of the camera? The mechanism for the shutter may be stripped or possibly just derailed. Can you move the shutter out of the way manually? Try a very delicate touch and see if the shutters will pivot out of the way of the lens path. Use a small implement. If the shutter moves easily, it is most likely a damaged mechanism. You can move them out of the way and secure them, at least your camera will work. The cost for repair is probably not worth it, but if it can be made usable, then it is worth keeping.
You can't post conmments that contain an email address.
Try downloading the picture to your computer to see if it is also black. If so, then yes it may be a shutter issue. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Am assuming that you've already tried pressing the DISP button on the back of your camera. Is it not taking pictures, or are the pictures it is taking also black like the LCD? If black pictures, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Am assuming that you've already tried pressing the DISP button, and that didn't fix it. Have you tried downloading the photos since this occurred? Are they also black? If so, then you're likely experiencing a stuck shutter.
It sounds like a stuck shutter. As the camera is less than a year old, Nikon should fix this for you for free under warranty. Contact them.
For others that experience this with cameras that are out of warranty:
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
