Hot point vbxr1070woww wont spin and drain
SOURCE: hot point washer wont spin i dont know how to
There may be two screws in the top ... if your filter is on the top ... otherwise pop it up (held down by spring clips). Hold it up - look inside to see what holds the front on - probably two screws at the top.
Move the front out of the way ... the drum will fall forward. Be careful of the door switch.
There should be a belt about 1/4 inch wide around the drum. If you dont see it ... that is your trouble. Find it on the floor.
Get a replacement at a appliance parts place or ...
visit www.partscinic.com . They will have it and they are also very helpful.
Expect to spend about 2 hours on this project.
Good luck with your projectc.
a
