Nintendo Wii Console Logo
Posted on Apr 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Wii console will not accept games or eject them, we think there is a penny that has been put in it. How do we fix it or get it fixed?
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 91 Answers
  • Posted on May 05, 2010
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
91
Questions
0
Helped
15093
Points
257
An easy way to "force" the disc out is to just
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
this should result in minimal damage to the disc. I've also heard of a way that involves holding down the eject button for a little while and it should force eject too.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
122320
Points
Find the culprit who put the penny in there, and demand they pay to get it fixed or else lol
When I insert a disk into my wii console, it will accept the disk, make a clicking sound and then eject the disk. This happens with every wii game i've tried. Any suggestions?
my friend,Christina, had the same problem, but didn't handle it right. SHE threw it on the ground. Don't do that. Just take it into GameStop. Then you can either get it fixed, or you can trade it in for a new Wii.
1helpful
My wii is not accepting any disc. I push the disc
I have just finished fixing a wii system that did the exact same thing. It had 2 pennies jammed into it. After i removed them it was perfect. I am a game sytem technician and a special type of screwdriver is required to open the unit. It can be purchased on ebay.Good Luck
Disc will not eject
There's probably only something jammed in the DVD drive... last one of these I fixed had a penny that my friend's daughter tried to stuff into the system. Once we opened up the Wii, the penny fell out and everything worked great. If there's nothing jammed in the drive, there may be gears or something in there broken. The following website has the full DVD drive... but I would try opening up the Wii first to see if something is jammed in there:
http://store.richspsxparts.com/wiiredvddr.html ~ Wii DVD Drive
http://store.richspsxparts.com/gbatrsc.html ~ Special "Nintendo" tri-wing screwdriver
Wii will not accept or eject discs it does show blue light and the disc inside is turning
I think you put it the wrong way. Let nintendo fix it if you still have your warranty. The disk is jammed. You can fix it but i prefer not cuz it will scre wup your warranty.
Our Wii won't accept or eject discs. Everything else is working fine and you can hear it trying to eject. I had to use a pair of tweezers to get a game out the other day! Any ideas on how to fix this?
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
1helpful
Game wont eject from wii console was put in sideways, wont play or eject
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.......
1helpful
Wii won't pull disc in
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.................................
A gamecube game is stuck in wii... Please help...
You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show Step by Steppictures to fix the problems yourself without any technical knowledge.
I need help with my wii console
If you feel comforatble taking the wii apart, I suppose you can try it. But sounds like, that since there is a disc reading problem now resulting in the penny, I would let a pro fix it for you. (Since those things are both expensive and hard to come by these days) Here's the number for Nintendo Support. You can try to see if their tech-perts can give you any ideas, or otherwise, they can at least direct you to where you could have it fixed. :) Good luck!! Hope you get that fixed!
1-800-255-3700
2answers
Don't eject discs.
try holding it down
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
