My nokia 5220 hangs during startup. I see the Nokia welcome screen and after a minute, it changes to a white screen. And then it doesn't get any further.
is it completely white or its getting white after somtime.....if it is getting white after sometime then it can be software or hardware fault...but if its completely white then I think its ur LCD problem....get it changed
it problem with your rom memory which don't hold firmware.again flash it and sell it. or second option is got it to nokia repairing shop to repair itsmain memory.
hi , it have the software problem. so you need to reinstall or flash the mobile. you can use service softwares like phoenix . If you have not sufficient idea about how to flashing , then it is better u to go the nearest nokia service centre.
When this occur on your phone, you have to change the screen of the phone because the screen is faulty.
To do this, get a screw driver and unscrew the phone. Open the phone and remove the screen. Take the screen to phone accessories shop and buy the exalt screen you remove in the phone. Get home and fix the screen your problem is over.
It sounds like you overloaded the CPU which forced it to reboot. Try removing the battery unit from behind, leaving it for 5 minutes, then reinserting the battery unit and switching the phone on. Give it a minute to fully load, then try opening your contacts and messages. If there still seems to be problems, services is where you should go to and have it checked.
