Restore Toshiba to Out of the Box Condition If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition. 1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook. 2. When the machine Starts beeping; release the 0 key. 3. When prompted by the warning screen; select Yes to continue with the system recovery. 4. Select Recovery of Factory Default Software; click Next. 5. Select Recover to out-of-box state. 6. Click Next again. 7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Your laptop:-"Toshiba Satellite A75-S209" is compatible with the Windows 7 operating system.Thank you for your time and best wishes for your effort.
Remove any new installed programs or drivers.
run a malware scan
use system restore
If the pc runs hot, check if it has good ventelation and the fans are spinning, good to use compressed air to blow out dust from the fans check if the pc has been overclocked and make sure to set to run at recommended speed.
Well, when I apply 5V to the fans they spin just fine... I am not sure why they need to be replaced. Could it be something else?
Thank you.
