Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
Whirlpool jacuzzi tub is not turning on when power button is pressed. is there a way to check the switch?checked connections and looks like power is going to the tub.
    Scholar:
  • 122 Answers
There might be a fuse at the pump that has blown
Posted on Apr 19, 2010
SOURCE:
We turned on our soaker tub, ran it for a bit, then it wouldn't turn off. I then flipped the circuit breaker off and now the tub will not start when you push the start button. Model B950.
If the switch is an air type switch check the tubing connected from the switch the control for kinks or pinched spots. This could be the cause of the problem. Hope this helps.
Bob
Jul 04, 2014 | Jacuzzi Tara, Whirlpool Bath -...
Jacuzzi tub will not turn on button will not click on as usual
Your problem is most likely NOT the air button but the switch in the motor.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Rod
US Parts Center
Apr 10, 2014 | Jacuzzi Home
Jacuzzi majic touch won't turn on
Air Switch Repair
US Parts Center
Nov 28, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Asteria will not turn off
How do you turn this on? If it is an air button that you push, it may well be the air switch in the motor is bad. The air switch is latching so when you push the button on the tub it closes the switch and lets the power go to the motor. When the button is pushed a 2nd time the switch will open and shut off the power going to the motor.
An air switch will cost about $21 to purchase.
Rod
US Parts Center
Aug 23, 2013 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Regarding a 30x60 indoor jetted tub (Jacuzzi). When I push the on/off button, the pump slows down but then a few minutes later starts again on its own when there is no water. Any idea what is going
IF that is the one I recall, the switch is not connected to the tub. When you press the button, it sends air pressure to the switch under the tub to activate it;. You need to check the tubing and the switch
Feb 22, 2013 | Jacuzzi Home
My jacuzzi motor is not working
When you push the button and the motor does not turn on there a couple of things to check.
Is there power to the pump? check the circuit breaker
If there is power to the motor then the air button on the top of the tub may be bad or it could be the air switch inside the motor.
Rod
US Parts Center
521-6183
Jan 11, 2013 | Jacuzzi Home
I have the Jacuzzi DX50 Elara7242. I plugged it in after not using it for 3 months and no power. Fuses, circuit breakers, power connection checked? Any help?
the only thing I can think of is checking all the power connections on the electonics of the tub. Making sure all those connections are snug
Jan 22, 2011 | Jacuzzi DX50-959 Elara 7242 Salon Spa...
Jacuzzi tub wont power off or on by push switch to turn off or on i have to use power supply
The button is worn out. It should be a relatively inexpensive repair whether you do it yourself or have a technician drop by.
May 17, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
699 people viewed this question
Top Whirlpool Home Experts
US Parts Center
US Parts Center
Donni Steen
Craig Butler
Craig Butler
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
