I have a printer of DCP-195C. I have used for this printer for doucment and Photo printout. When I print the snap some linning on prinout. I have purchase this printer in May, 2010. I use the cleaing command but not solve my problem.
I have brother printer DCP-195C but i cant fix it. the problem is the black ink did not function. i have tested for print quality for five times but black ink did not appears. how can i fix it?
Cannot detect cyan ink reinstall sllowly
SOURCE: Brother DCP-195C Compact Colour Inkjet ... i have
Brother DCP-195C Compact Colour Inkjet error unable clean 46
If the yellow ink is not printing here's what you
can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to
select Test Print, then select Print Quality press OK and press
Black or Color START. Check all the colors including the black & check if
there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select
cleaning press ok
3. Press the up or down arrow key to select Color press ok and press
Black Start.
*After the cleaning process the printer will ask you if the quality is
OK, press up or down to select yes or no, and it will ask you whether black or
color is ok, once you have selected you're answer press Black or Color START to
print another test page. Compare the 1st and 2nd test page if it's
improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps.
Rate if it worked Thanks!
hi, I have the same problem.. Have you already fixed yours? how did you do it, if you did.. pls help.
Hi there, same problem with my printer.. Please let me know if you fixed yours. tnx
