Question about Life Fitness T3 Treadmill with Advanced Console
What does FET Error mean on my treadmill - Life Fitness T3 Treadmill with Advanced Console
    Problem Solver:
  • 11 Answers
Fet error is caused by the drive component(s) on the motor control board going open circuit or faulty. This is caused by poor power supply or excessive friction on the running belt which in both cases leads to excessive heat build up in the control electronics.
The Motor controller will need to be repaired or replaced and the heat issue resolved.
Posted on Apr 27, 2010
4 Suggested Answers
6ya staff
SOURCE:
bwinton
Ben Winton
  • 83 Answers
SOURCE: Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Posted on May 07, 2010
bwinton
Ben Winton
  • 83 Answers
SOURCE: FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Anonymous
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
What to look for with the mc2100?
Hi There.....that's slightly vague, as it depends on which circuit(s) aren't functioning, like the console lights? Yes? Motor runs? no? There are no "simply replace these 3 parts" and you're fixed, but I can tell you a couple things.... there are "lethal" voltages/currents on these controllers when powered up, and a failure to catch "all" electrical issue's before retesting can cause a total "rip" as we call them, meaning you literally "rip" all replaced parts and those leading to and from the root cause issue ;o) For no/excess belt movement check the main switching FET for problems, if problems found, you must check the kickback-diode for problems it can experience if/when the FET rips. If both are toast, you must go back to the driver IC and verify that is good, and if good you need to go back to the micro to verify it is sane ;o) You can find repairs and refurbished motor control boards by emailing gregATbuyfitnessrepairpartsDOTcom
Feb 09, 2016 | Proform Xt 90 Treadmill Motor Controller...
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
Why does power on but treadmill doesn't move?
DEAR
IF YOU LISTEN SOUND OF RELAY AFTER START YOU FORGET SET MOTOR WIRE IN OTHER WISE YOUR MOTOR CONTROL BOARD IS DAMAGE
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 31, 2017 | Horizon Elite 1.2T Treadmill Walking Belt
Error fet
haga un RESET de la maquina . Recomiendo que Corra el Software calibration for facil diagnostico y reparacion que viene con la maquina. lea su manual de instruciones. or bajelo de
www.fitness.manualsonline.com
Dios le bendiga.
Jun 19, 2013 | Life Fitness T5-0 Treadmill Fitness...
Feb 20, 2010 | Exercise & Fitness
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
FET Error
Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
Fet error message
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
Open Questions:
See all Life Fitness T3 Treadmill with Advanced Console Questions
Life Fitness T3 Treadmill with Advanced Console Logo
2,245 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Android Man
Android Man
Kenneth Simmons
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
