Issue:
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution:
Reseat the print head iP3000
- Confirm that the printer is powered on.
- Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
- After confirming that the print head holder has moved to the center, open the inner cover.
- Remove all ink tanks
- .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push
down on the PUSH mark on top of the ink tank until a click is heard.
Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Issue:
Solution:
2 Reset the printer
Resetting the Printer
By resetting the printer's power, the print buffer is
cleared and certain sensors are reset. If there is invalid data in the
buffer, or sensors are stuck in a particular mode; errors may occur.
Follow these steps to reset the printer:
- Turn the printer off with the Power button (if available).
- Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
- Unplug the printer's power cord for approximately 10
minutes, and then plug it back in. If troubleshooting a communication
issue, reconnect the data cable (not applicable to WiFi, Bluetooth or
Infrared).
- Turn the printer back on.
