Compaq Evo N600C PC Notebook Logo
Anonymous Posted on Apr 18, 2010
I Have A Compaq Evo N600c Laptop No Power Help!!!
I Have A Compaq Evo N600c Laptop And It Will Not Power On. I Don't Get Any Blinking Lights Or Anything. Do You Think It Is Because I Am Trying To Use A 19 Volt Charger Instead Of 18.5 Volts?
Anonymous
Level 1:
  • Contributor 51 Answers
  • Posted on Apr 18, 2010
Anonymous
Contributor
Level 1:
Answers
51
Questions
0
Helped
9622
Points
97
Yeah it could be. Always use the correct adapter mentioned for your laptop. Otherwise it could harm the inner wirings and the motherboard. Always go for the right adapter. If it was any motherboard problem, atleast it would've blinked. So this might be the problem of your adapter or may be of the power button.
Testimonial: " "
Compaq evo n600c start up has an email in it ask for a password but wont let me type it in and f10 thers an error
Entering and Exiting the BIOS Power on the system. Press F10 when the blinking cursor appears in the upper-right portion of the screen. Select a task from the following menus: File, Security, or Advanced.
To exit the Bios, select the File menu. Choose either Ignore changes and exit or Save changes and exit, and then press Enter. When you are prompted to confirm your choice, press F10
Compaq Evo N600c Laptop over 5 years old but has been working fine. About 2 months ago the screen went dark (bad lamp?) so been using an external monitor. Turned it on this morning and it started to boot...
Do you see any lights on the laptop that are on? If you see any lights and only a black screen, then more than likely your video chip on the motherboard has gone out. Some local shops might be able to replace the motherboard it might be cheaper than buying a new laptop. Good luck
2answers
I AM LOOKING FOR A LAPTOP BATTERY FOR MY COMPAQ EVO N610C A GOOD LOW PRICE.HI-CAPACITY LI-ION (4400MAH 8 CELLS) FOR COMPAQ EVO N610C
don't waste money on buying second or used.
buy original from near HP store or order online. check HP center near
N600c laptop manuals
Go on this site and download it...
http://pdftown.com/Compaq-Evo-n600c-Service-Manual.html
1helpful
Compaq evo n600c battery wont work
wrong battery for it or connectoers on battery dirty could be the charger for the battery is bad and shorted battery out
All white screen on compaq n600c
When you hooked up external monitor, did you switch to it via "Fn" keys?
If it did not help, then it's GPU ot North Bridge on the board that needs service.
Need help with Evo N600c battery Pack
Wouldnt fancy taking one apart myself, replacement ones are not very expensive, look here on battery trader , Compaq Evo N600c laptop battery
2answers
Reboot
You can insert the OS installation CD and hit F11 or F12 to get to the boot menu. The you can wipe out your hard drive and put a fresh copy of windows on it.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
