Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V ) If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle. Reset Procedure
Make sure that the machine is turned OFF.
Make sure that the door is opening.
Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
Make sure that the door is latched properly.
Set the washer knob on the Red Reset position and switch on the power.
You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
Once the light starts flickering slowly turn off the power.
Set the washer knob to the Green Reset Position and switch on the power.
Set the washer knob to the Grey Reset Position and switch on the power.
Set the washer knob to the Reset Position on Delay Time and switch on the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis. Hope this procedure helps.
The flickering problem you have is caused by a failing power supply. There are parts called capacitors that are failing and causing the power supply board to put out pulsing voltages until it can stabilize. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you can soldethen you should be able to do the repair yourself. If you don't want to do the repair we offer a repair service for this unit. You can get details for that service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
The black box with 4 large red wires in it is the high voltage distribution box. One red wire brings the high voltage in and the other 3 bring high voltage to each of the 3 picture tubes. If those red wires are not all the way in and tight, then there will be high voltage arcing inside that box and the picture will rapidly flicker. Make sure all red wires are pushed all the way into those holes and your picture should be back to normal. Convergence IC's will not make the picture flicker, so I am sure your IC's are fine.
If by saying the "aspect ratio changes" you mean the picture shrinks from top and bottom, I would suspect an intermittent short inside one of your picture tubes. The commercial skip function is not causing a problem here. It is the rapid change from dark to light that I believe is putting an extra strain on a weak or defective picture tube.
