Danwtodd
If you have lost the CD key for the software you will need to go back to the manufacture to see if you can get a key from them as they were the ones to licence the software.
Now it is possible that the key is still on your computer if it did not get formated. Please describe alittle more about what happened to your programs.
Issken
http://www.fixya.com/users/issken
Just plug your INport into a USB port on your computer and all of the necessary drivers load automatically.
You can follow these steps as per their website.
1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA PROPERTIES -> AUDIO TAB
2. Make sure that in the Audio tab your soundcard appears as the Preferred Playback device with USB Audio or INport as the Preferred Recording Device. There should also be a check next to the option 'use only preferred device'.
3. When you start LPRecorder you should also make sure that Recording Device is set to USB Device or INport and Playback Device is set as your soundcard and that there is a check next to the option Simultaneous Playback.
4. You should then be able to hear as you record and play your recorded
files once done. If you can't, your soundcard will be incorrectly
holding onto the audio resources. You can unplug your INport to hear
the files, but should update your soundcard drivers in order to
playback files with the INport still plugged in.
Please let me know how this goes.
i am trying to reinstall my INport without the security code . My computer lose all its programs . I don''t know what I did with the code .
