My playstation 3 wont turn on. the red light is on in front but when you try and turn on the ps3 by holding the power button down the green light turns on then blinks yellow then goes to red.
SOURCE: My playstation 3 goes green then goes yellow and
Sadly what you are describing is called the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components hairline cracks formed in the solder joints between the CPU and GPU and lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years
Hope this helps and thank you for using FixYa
