Hello :
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
PLEASE DON'T FORGET TO RATE !
SOURCE: my mp3 player wont turn on.
hiya I have a sony bean too and it does exactly the same thing as yours, if you havent sorted it out yet all you have to do is look under the usb flap and you will see a reset button, push it gentally with a pin, it will work agauin and you wont loose all your music, hope this helps
SOURCE: it wont turn on but it is fully charged
damn yo...i have the same problem....today all of a suden i turned it on, the green light stays on for about 5 seconds, then it just turns of, and its 80 percent charged!!
SOURCE: I cant get my coby mp3 to charge?
That's because u didn't plugged in your computer. Your computer have to be turned on..
SOURCE: cant get my mp3 to work.
USE DEVICE MANAGER INBUIT IN CD OR DOWNLOAD FROM WWW.PHILIPS.CO.IN
USE REPAIR AFTER INSTALLING THE SOFTWARE.
YOU NEED TO PRESS RETURN KEY WHEN SOFTWARE IS ON..IT WILL PROMPT U TO REPAIR THE PRODUCT AUTOMATICALLY.
REGARDS,
PHILIPS INDIA LTD.
SOURCE: a frozen mp3 that wont turn on after fully charged
try pushing a the reset button. if that does nt work plug the mp3 player to your computer and do a firmware update
