Whenever I try to load certain programs, the window will open, but upon clicking on it (anywhere), they will close. No error message is given. The programs I have tried are Windows Live Messenger, iTunes and Windows Media Player.
The problem continues when I try to load any ''social'' websites, such as Last FM, Facebook and MySpace, causing Internet Explorer to close instantly.
I ran a Windows OneCare virus scan last night and it found, stopped and removed one potential criminal. However, the problem persists. I think this is virus related as for a short while last night our wireless (NetGear) was changed to 'open' i.e. anyone could connect. This is substantiated by the fact the same problems are occuring on my laptop. Before it was changed, the problem was non-existant.
Yes, it sounds like a computer-virus.
Remove the disk-drive from your desktop computer,
and attach it as a "slave" disk-drive to some other desktop computer, and then run a full virus-scan.
Or, just follow "best practises":
* backup your data & music & E-mail & contacts,
* reinstall Windows from trusted media,
* run Windows Update a bunch of times,
* reinstall anti-virus software,
e.g., http://www.microsoft.com/security_essentials
* reload your files.
Microsoft Office may need to be repaired.
Go to Control Panel
Add Remove programs
Find your M Office
Click change/ remove
Choose Repair option and let it run
That should fix your problem
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Freezing often occurs when your computer is receiving several commands at the same time.
First check your Startup Menu and turn off (uncheck) any programs that don't need to run upon starting up (Go to Start, Run, type in MSCONFIG, select "Start Up" tab and uncheck those needless programs). You can always turn programs on manually when needed (such as media players, games, Instant Messaging, etc.)
Second, check the Options or Preferences in your anti-virus and anti-spyware programs and make certain you don't have a constant scan occuring that will slow down your applications.
Third, turn off any programs or applications that might be running but that you're not using. The fewer programs you have running at one time, the less your computer has to process.
Fourth, when your computer freezes, click on your Control/Alternate/Delete keys at the same time and only once. A window will open called a Windows Task Manager. Select the "Applications" tab if it's not already selected, and highlight any programs which are "Not Running." Then click on "End Task" for those programs only. This way you don't have to restart your computer.
Fifth, notice those programs that seem to cause your computer to freeze and either remove them, replace them or reinstall them.
The issue happens due to quantity of applications at the background. Reducing the quantity of startup applications might help. Just type MSCONFIG after clicking run, At startup tab uncheck the non-essential applications If you need further assistance please post Good Luck
Gphone.exe is worm which spreads via instant messengers. It usually affects Yahoo! Messenger and Google Talk applications. Gphone.exe send a message and invites victims to visit a website. If clicked upon, the link actually delivers a copy of Gphone.exe infection.
Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup, thankfully it isnt able to because the threat is gone so windows is displaying that error message to let you know it was not able to load the file.
Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:windowssystem32).
yahoo messenger 9.0 was not loading for me....so i tried to re-install it..tht ddnt work...thn i deleted all the files manually and removed the program... but now wen i install it it stops at 99%..i saw somewhr a suggestion...it helps to reach 100%but again the loading prob.. so in short nothing worked out.. i tried several times to install... it stops at 99%.... YAHOOOOOOOOO plzzz help. i use windows XP.
open up your email program go up to the top left hand corner and click on tools and then click on options go to the send tap and see if the close after sending box is checked if it is uncheck it save and close close out your mail program and reboot when you restart the program should be fine
