The audio cable will depend on the source and the TV. If you are using a computer as the source, you probably need a 3.5 mm male/male end stereo audio cable (like for computer speakers that aren't directly wired). Plug this in to the computer's speaker (out) jack and the TV's audio in (not the headphone jack on the TV). The other possible cable would be an RCA audio cable with two colored jacks on each end of the cable. For a computer to a TV that doesn't have a 3.5 male audio in jack, you may need an audio cable with the 3.5 mm jack on one end and the pair of RCA jacks on the other.
I hope this helps.
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
