I have an LG washer slightly different model but had the same problem. It washed the clothes but then the light would stay on but the washer would not turn back on. Remove door switch unplug wire that conects and check the connections. which requiered taking off the top and front of the washer. Mine were corroded after only 2 years. We cleaned the connection and it seems to be working fine again.
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports. There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four. If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled. Good luck!
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
