Hi. I just purchased a used pfaff creative 7550 from an estate. The machine had a code set by the previous owner and no one knows what it is. Is there a way to reset the code, or disable it?
Thanks!
The 7550 has a battery backup (little door on bottom of machine - 2 AA batteries). Remove batteries for a couple of days and the code should disappear. Removing the batteries WILL NOT effect the main memory of the machine - they are just for the backup of any personally designed stitches and memory combinations - not the hard memory of the machine. Periodically these batteries will need to be changed - a message will pop up on the screen to let you know.
Hope this helps (ex-Pfaff employee - GREAT MACHINE!)
I found this solution while looking for something else.
found this solution http://www.cyberport.net/users/milnerwm/FAQ.html
Emergency password deletion
Special thanks to Mel Patrick <[email protected]>) for
finding a solution to erasing the code lock [page 64-65
"Pfaff Creative Instruction Book", if you do not remember
your Pfaff's password or Pfaff self locks.
Thu, 14 Jun 2001
SO....I unplugged the machine from the power cord, removed the foot
control, and I once again removed the batteries. But this
time I left them out for at least 20 minutes.
There is some RAM in the machine that holds the P and M
memories plus some "preference" info like the codelock
sequence. There is a capacitor that stores some electricity
from the battery (or the power cord maybe), that enables you
to remove all power, change the batteries in a reasonable
amount of time and not lose any of the memory stuff.
However if you remove the power long enough, the capacitor
drains just like a battery and that resets the
machine to null.
Now as to why this [phantom password] appeared, perhaps
that it's because:
1. we removed the power cord for so long
2. the batteries were low (although this doesn't make much
sense when
I measured them)
3. the machine had a battery "burp"...;-)
Mel Patrick
wCEO
Wabbit Wanch Design
www.wabbitwanch.com
TURNED MACHINE ON AND LOST ALL HARD MEMORY ON THE MACHINE. CAN THIS BE REPROGRAMMED?
Thanks!
My display screen is totally blacked out does anyone know how I can recover
