AEG Santo 3888 KG8 Bottom Freezer Refrigerator Logo
Posted on Apr 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My brother has a AEG fridge freezer he thinks the part number is either R600A or 412 or KG2 we need new door seals for both doors can you advise the part numbers needed? it is a fridge at the top and a freezer underneath if this helps many thanks
Anonymous
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Apr 18, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
20113
Points
111
The R600a is the isobutane gas in the system. The 412 is probably the alternate gas to be used. The KG2 is probably the weight. You have the make & model number above. most magnetic door seals will fit you buy it in a roll and cut it to size.
2answers
Fixing the springs on the door seal of a Fridge Freezer
no maker ,no model number told
and moved this from cars to fridge.
Candy CPCA240FFK top fridge door seal required?
They need to be for the model itself as opposed to by size
Candy CPCA240FFK Seals - Fridges & Freezers - eSpareshttps://www.espares.co.uk > ... > Candy > Seals
Fridge/Freezer Door Seal. 3.6. Genuine spare part for select models of Candy, Hoover and Kelvinator fridge and freezers More information. In Stock.
Candy Door Seal for CPCA240FFK - ES929589 - eSpareshttps://www.espares.co.uk > product > door-seal
Will this part fit my Appliance? Yes. This part is compatible with Candy CPCA240FFK Fridges & Freezers. Not what you're looking for?
Candy CPCA240FFK Fridge & Freezer Door Seals - Ransom Spareshttps://www.ransomspares.co.uk > ... > CPCA240FFK
Buy Candy CPCA240FFK Fridge & Freezer Door Seals from the authorised stockist. Low prices with our Price Match Promise & next day delivery - Ransom Spares.
Candy CPCA240FFK Fridge & Freezer Spares & Partshttps://www.ransomspares.co.uk > ... > Candy
Buy genuine replacement Candy Fridge & Freezer CPCA240FFK spares from an authorised supplier. Price match promise and next day delivery.
Finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
I have a Defy C380, its a 2 door fridge with the freezer compartment at the bottom. The freezer compartment makes ice after about 12 hrs, I need to efrost the freezer weekly. There are gaps between the...
Door adjustments instructions should be found in your users manual. No manual, follow this link.
http://www.manualsonline.com/
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 31, 2017 • Freezers
Have a 2 door 520L fridge/freezer (freezer at the top) and the fridge door isn't sealing. We would like to know how we can adjust the door so that it stays closed as in this hot weather the motor is...
is the seal new usually when we put a new seal on the door we use petroleum jelly aka vaseline around the entire door seal and shut the door for about two hours this causes the seal to mold to the fridge door while it is closed and also increases the amount of adherence to the door cabinet as well send me your model number so i can look up your model and send you a schematic so you will be able to adjust the door Thanks again
Rick
p.s please remember to rank or post testimonials when our chat has concluded as well and if you have any further questions message me back Thanks
1helpful
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 • Freezers
Refrigerator door opens on its own
needs new door seals or door adjustments
79helpful
23answers
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Top AEG Refrigerators Experts
kelly
kelly
David Spradling
David Spradling
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
