Olympus vg 170
To make it possible, to point out where the problem is, you could try some rings.
Try to charge the camera with an external power supply. If you have it, the F-2AC from Olympus.
If that also does not charge, you could try to replace the USB cable.
But if the camera starts charging, you have to look for the USB connector in the computer. Be aware, in some computers the power, delivered from a USB connector, should be capable of giving 5 volt and 500 mA. Sometimes internally the computer is not correct wired, and won't give the 5 volt at all. Special when you hav build the computer yourself, you can check inside the computer. BUT ONLY when is sure the camera can charge via an external USB charger.
Then you could check if nothing is wrong in the camera. All contacts, on battery and in the camera, should be clean and shiny. You could clean contacts with a dry cloth. Never use sharp tools.
Also check the USB connector on the camera, if no debris is in the connector, or no contact is bent or has corrosion on it.
Success
