Make sure your water taps are on full, the hoses aren't kinked or bent and if there are any small filter screens to the machine water inlets that they are not blocked with debris. The H20 error is indicating the machines' water level is being interfered with somehow.
H2O error appears on the scoreboard in the washing machine when there are problems with water.
H2O error in the Indesit washing machine means that in the allotted time the water did not collect enough to wash or rinse.
If a larger volume of water enters the drum than is necessary for the washing or rinsing process, the cause must also be eliminated.
After starting the washing 5-10 minutes from the start, before that, you could observe such processes - thst the The Machine Did Not Get Water At All. otherwise it's Little or too Much.
code showing h20 is the clue water is also known as h20,so your problem is the inlet valve letting the water into the back of your machine needs replaced or water pipe is kinked and no water is at the supply,. these valves are cheap at 10 dollars,adrian.....
hi, the problem you are having with the "soak/prewash" light flashing after the wash has started is a common fault on the meile washing machine. Its a water sensor problem. remove all srews and bolts from front of machine and open the front panel. you will see a red in colour pressure switch at one oclock, there will be a black tube attached to it, remove the tube and replace it with a new one, or reverse the tube in reverse and you will find that the water intake level will be less and the fault of the "soak/prewash" light will no longer flash, problem solved. 0868887054 DAVID ASHBOURNE. MEATH.
Hi.
Fault code H20 is indicating that the washer is not filling correctly, check tap/s hoses, and inlet valves for water supply.
Please rate my solution.
Thanks.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Pl rate if helped..................
For guest dated May29:
If you still don't have water going into machine you have to plug off the wall mains, open the top of your machine to see if the three tubes are connected to the dispenser tray. Connect securely & check for leaks before you close the top. You did not say there was any leak, so this may not be the problem; it could only mean that the inlets were clogged. Another way would be to clean out your dispenser tray.
Indesit washing machine error code 3 (F03)
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows - NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
If the pre wash led is flashing it indicates a h20 error (time out filling) some common causes are fill hose twisted trapped or kinked tap not turnd on the waste hose is connected incorectly and is causing the applionce to syphone if your waste pipe gose into a down pipe ensure it is in no more than 4 inches maximum and if it is connected to the u bend undr the sink you need to make sure the pipe gose above 60cm high at some point.
