Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
I have the same problem with My sharp Aquos LC-46D82U, Tv power on (solid green light at the bottom right) but NO sound and No picture. When I try to reset using Vol - and Channel - button, The blinking pattern of lights are
- power light blink 2 times then both Power + OPC light blink once and the same pattern is repeated..
nothing appears on the screen (no K on top left), when i press Vol - and Channel - together.. so any insights what might be the issue.
Go to this site: http://elektrotanya.com/sharp_lc-42d64u_46d64u_52d64u.pdf/download.html
search for your service manual and click on the underlined words at the bottom Get Manual. It's free.
I set up a home theater system upstairs in our house. It's been pretty great watching movies and games on our 120in projector screen Amazon com MALLCROWN 3D 1080P 4 Pport Hdmi Splitter with ac power adapter...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
I have the same problem with My sharp Aquos LC-46D82U, Tv power on (solid green light at the bottom right) but NO sound and No picture. When I try to reset using Vol - and Channel - button, The blinking pattern of lights are power light blink 2 times then both Power + OPC light blink once and the same pattern is repeated..
I try to follow what you listed here but there is nothing (no K on top left) appears on the screen.. so any insights what might be the issue.
