You can reset laptop login password with Smartkey Windows Password Recovery, just do as the following steps,
Step1: Quickly download, install and run this tool on an accessible computer.
Step2: Insert an empty and writable CD/DVD to the computer
and start to burn it into a computer password reset disk with Windows
Password Recovery.
Step3: Insert the burned password reset disk to the target/locked computer, and set this PC boot from CD/DVD.
Step4: Reset forgotten laptop password with the burned password reset disk in less than 1 minute.
Step5: After computer password resetting procedures finish, reboot your PC, and then you finally reset laptop login password and regain access to your PC.
Have you try to reset asus password in safe mode? The steps as following: Step1: You should restart your computer, andkeep pressing asus/F8/F2 to enter the Safe mode. Step2: After enter the safe mode, you can see the default administratoraccount, just click it to enter the system. Step3: Open User Account in control panel, pick the account you have forgottenthe password to change the password. Step4: Restart the computer, you will log on with the newly created password orwithout password If the above method can not help you, you can google search for Smartkey Window Password Reocvery to reset windows password. Hope it help you well.
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password, but you forgot administrator password, that way doesn't work. you must use software to recover administrator password. This method is very easy. You can go to this site http://www.reset-windows-password.com/how-to-reset-windows-password.html
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password As an easy method to recover the forgotten Windows password, there are only four steps as follow: Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com )and install it. Step2: Burn the ISO image file onto a blank CD/DVD or USB. Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes. Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
In the grub loading add the following entry at the end
linux single
and you`ll have only have your shell mode. You`ll not be asked to login. Once the cshell pprompt appears type the following passwd root. enter the new password that you want and retype it. Nad after that type init 6
Restart the computer, and keep pressing the F8 key, then choose to load into Safe mode. Once in safe mode, it should give you the choice to log in as the administrator account, which hopefully doesn't have a password, and then once logged in there you can reset any of the other profiles passwords.
*If you have the log in screen where you enter in your account instead of choose the icon, just type in administrator into the user name field and leave the password field empty.
yes there is goto yahoo or google and search for log in password recovery should be able to find a program to recover the password if not then you will have to reboot the entire computer with the reboot disk
