ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
Posted on Apr 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size hammer should I use on my Asus Eee 1008HA? Little.....by.....little...worse & worse. Simple programs won't initialize, check disk upon start-up, Even Norton Internet seems to have a problem on this. Don't even own this 4 months yet. Stop me before I....
Anonymous
Level 2:
  • Expert 144 Answers
  • Posted on Apr 17, 2010
Anonymous
Expert
Level 2:
Answers
144
Questions
0
Helped
78379
Points
472
STOP!
If you have a broken system , you could happily post it to me! (No im actually being serious here)
Either :-
Pay return shipping and handling plus $100 and il send it back repaired
Or
Pay nothing , il pay shipping and post it me
Seriously , if your thinking of smashing it id appreciate the spare parts for my business
Regards
1234s282
Swollen battery ASUS Eee 1008HA
I recommend you contact ASUS support and explain your battery problem. If you laptop is less than 12 months old it may still be covered by warranty.
tip
Review Asus Eee PC 1101 HA
asus-eee-pc-1101ha.jpg The Eee PC 1101HA netbook with a 11.6-inch display. For this and its characteristics could be defined almost a notebook. Obviously, a larger than normal netbook weighs more, but the Asus Eee PC 1101HA is a netbook with mobile calling. Asus Eee PC 1101HA promises up to eleven hours of PA3420U-1BRS battery life, thanks to the Intel Atom Z520 chip.
Homes and Design
The Eee PC 1101HA has the same form "shell" 1008HA Asus Eee PC. The case is polished and its shape makes it particularly elegant netbook. We noted that despite the gloss paint handprints not remain imprinted on the case easily. This Asus Eee PC 1000H is available in white pearl, black and pink crystal.
The hinges Eee PC 1101 HA self-locking (no mechanical locking) but well hoods that limits the opening angle to a maximum of 130 degrees, this makes little netbook fittings for use legs. The screen however is quite stable.
Autonomy
Asus EeePC 1101 declares that HA is able to provide even eleven hours of VGP-BPS2C battery life. Indeed, the netbook can reach eleven hours, but with the six-cell DV1000 Battery and without Wi-Fi active since our test Eee PC 1101 HA has worked from time to time reaching autonomy of 10, 48 hours. The test was performed with a non-intensive use and without wireless enabled. With wireless enabled netbook's Inspiron XPS M1710 battery life decreases by about three hours.
Weight and Dimensions
The amp 11.6-inch display makes the netbook a bit 'pesantino (1.38 kg) obviously increases the overall dimensions: height 21.80 cm, width 28 cm, depth 19.60 cm.
Judgement
Cast a netbook for mobility, thanks to long HP dv4 Battery life, good performance that does not disdain. We can define Eee PC 1101HA netbook complete. In fact, the hardware equipment enables to easily perform common office work in comfort. With excellent value for money (currently about 360 million) this netbook is among the best in its class.
on Apr 21, 2010 • Computers & Internet
2answers
My screen turn off inside the OS or inside the BIOS, but I can resolve it for some seconds (30) moving (open and close a little) the lcd screen, but after that the screen goes the black state. The most...
This is caused by a dead backlight and video inverter. These are relatively cheap to replace and it only requires the display be opened and one is a plug in card and the other is a picture tube type lamp that projects the backlight portion of the LCD, which in turn enables you to actually see what is on the display. Take it to any descent computer guy and it should cost no more than $60.00 to fix. Let me know if you require additional information..
I do not have my recovery dvd for my asus eee 1008ha PC. what do i do?
Sometimes you can contact the manufacturer and they will send them to you, with a charge. Other times the recovery part is on a partition that you're able to boot from, check the manual for the key you would use to do this (usually F10 or one of the other F keys). Other times the PC was supposed to prompt you to create these yourself when you first setup the PC.
1helpful
How to fit a keypad to asus eee pc 1005ha
Hello, Please follow the bellow link and you can solve
http://netbookitalia.it/asus-eee-pc-1008ha-guida-disassemblaggio-e-upgrade.html http://netbookitalia.it/asus-eee-pc-1101ha-smontaggio-componenti-hardware.html http://cegeekbook.blogspot.com/2009/12/asus-eee-pc-1005hab-tear-down.html http://cegeekbook.blogspot.com/2009/12/asus-1005hab-disassembly-tear-down.html
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
2answers
I bought an Asus EEE PC 1008HA notebook in December and now it is starting to freeze quite regularly, a minimum of three to four times a day. I use it often and quite a lot, and I have tried cleaning out...
A laptop generally freeze due to following reasons...please note that in terms of computers..... Freeze and hang are two different things...
here are possible cause of freezing
  • The most common cause is your Hard-disk not attached properly and is loosing contact occasionally with the pins.
  • The same thing happens with the devices like RAM, etc.
  • Avoid fast motion of your laptop while using it.
  • Some people also claim that turning on the laptop's WiFi while not using it can cause freeze.
  • Voltage Fluctuation also causes freeze.
  • Low voltage can also cause occasional freezes.
  • One more important reason is Overheating.
Hope this will help......cheers :)
HOW CAN i RECOVER FACTORY SETTING OF ASUS 1008ha ?
if settings and image are on hard drive press F9 whilst booting(every other boot) choose (highlight) option press "E" then press "B" then go through initial logon pages.
Hi iv got a ee laptop an i needs an activation key code to remove threats
What activation code for which software are you talking about?
I need more info.
Regards - Anthony
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
