Warning when appending records does not work on desktop with XP but works on laptop with vista, why
SOURCE: midi cable wont work with vista
Just like mine. Well, go to http://www.esi-audio and click on the Midi Device Driver for vista. It should be MIDIMATE. Thats the new one. The cable is blue. If yours is white, then download MIDI mate for vista. They are both different, so better be careful.
SOURCE: how to connect a laptop having vista home basic with a xp desktop
Be advised that,
it makes not different to connect one PC/Laptop to another one via LAN because when you connect your system in lan networking you system will be automatically detected if LAN has been set up through a server.
And if not you need to do manually by assigning ID address on bot PC/Laptop.
For that,
first assign an IP address in either Laptop or desktop (IP address must be same category)
ex.
192.168.1.231 (first one)
and second one should be
192.168.1.here you can up (instead of 231) any number excep 0 but make sure not confliction between other system. means not duplication IP address on same LAN.
once you ae done with IP assigning
Go to
Star>Run>command and hit enter
once you see command prompt then
type there:
ipconfig and hit enter (it shows your ip address) if you wanna have more info then type ipconfig/all
once you are done with this then
you need to ping to your next PC.
for that
type in
ping 192.168.1.231 (means you need to type another PC's IP address here)
and hit etner
if you see like on image
then you are good to go.
Thank you
and rate all answers.
SOURCE: works perfect on laptop doesn't work on desktop computer
Solution
I think this is a driver issue. So make sure that if for instance you have VISTA on your other system and it worked fine with vista whereas on the home you got XP and you expected it to work tough luck! You got to make sure that you installed the proper driver for the OS. If you do not have this on the CD which came with it go to the lifecam vx3000 site and downlaod the driver suitable for your OS.
If still no luck with this I think I know what might solve the issue
1. Uninstall the webcam driver (from control panel ... add / remove hardware find webcam and remove)
2. Uninstall yet another time MSN Messenger
3. Disable any other webcam that you might have from the device manager as you didnt say if the you already got another webcam on home pc.
4. Download tunieup utilities install trial and run registry cleaner ... clean the whole registry for 2 - 3 times until its perfectly clean. Install the new driver you just downloaded
5 . Reboot
6. Install MSN Messenger
7. Reboot
SOURCE: changed laptop from xp to vista cd will not work
You need to download the driver for vista.
