Eforcity Apple iPhone 3GS 16GB / 32GB Screnn Protector W/ Micro Fiber Cleaning Cloth Logo
ABD RAZAK MOHAMED Posted on Apr 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Touch screen for my iphone not detect finger movement
Anonymous
Level 3:
President:
  • Master 239 Answers
  • Posted on Apr 18, 2010
Anonymous
Master
Level 3:
President:
Answers
239
Questions
0
Helped
58355
Points
1200
Try a reset. Hold down the power key at the same time as the round home key until
phone powers down. Release buttons only when you see the apple logo,
then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back
up essential data ie contacts apps etc, then go to settings general and reset. Reset
all settings as a last resort. This will give you a fresh start and should sort out
the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Hope this helps and if so please vote.
Thanks
Jim
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1962
Points
There is a clip under the front screen that goes to your glass digitizer when you clip it together it has to be perfectly in line or it will send the pic to your screen wrong. the clip is marked # 2
How do enable my touchscreen?
This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer) https://www.lenovo.com/shop/americas/content/user_guides/a720_ug_en.pdf
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Where is pc settings/ calabrate located in lenovo c260
From page 21 of the user manual, "The monitor is touch-sensitive thanks to its touch-sensitive screen. A touch screen is an input device just like a mouse or a keyboard, and the user's fingers transmit position information via the touch screen to the computer. With this technology, you only need to touch the pictures or words on the computer display lightly with your finger, and the computer will react. Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Control Panel, select "Hardware and Sound". 2. In "Hardware and Sound" window, select "Tablet PC Settings". 3. In "Tablet PC Settings" dialogue, click "Calibrate" button. User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor. 16 User Guide 31506537 C260 UG V1.0 (Win8.1)(EN)(R).indb 16 2013-12-6 11:54:06
We're is the LCD located in my phone
One of the iPhone's greatest features is its highly intuitive touch screen.
Unlike other electronic device touch screens, your iPhone doesn't operate using the blockage of light to decipher which keys and commands you're pressing.
This makes it a viable choice for cell phone users who may not be able to complete other types of commands.
While you cannot alter the sensitivity of your iPhone, you can toggle certain features that make your phone easier to use.
How It Works
The key to understanding the sensitivity level of your iPhone's touch screen is first understanding how the touch screen actually works.
Instead of detecting light blockages or heat to interpret your finger's movements, the iPhone actually has a grid that lies underneath the surface of the touch screen.
When your finger touches the screen, electrical impulses detect the area on the grid that you're touching to interpret the letter, command or motion you're making to issue the correct response.
Screen Sensitivity
While previous models of the iPhone did offer the ability to change the screen sensitivity and the speed by which your phone responds to commands, the iPhones 4 and 4S no longer offer the option.
Instead, the touch sensitivity on newer phones is automatically calibrated for the fastest speeds, which means your phone responds quickly to your touch.
If this frustrates you and results in commands and calls you didn't mean to make, locking the screen by pressing the button on the top right-hand rim of the phone helps stop unwanted commands.
Assistive Touch
Update iPhones running on iOS 5 with an option known as "AssistiveTouch," which allows users who may not have complete control over their bodies and motions to use the iPhone.
This program allows you to change the speed at which the phone responds to your touch.
By tapping the "General" icon, then touching "Accessibility" and "AssistiveTouch," you'll enter the assistive touch menu.
When you turn on the option, an overlay appears on the screen that allows you to give commands by touch, rather than by shaking, swiping or pinching the screen.
When setting up AssistiveTouch, you'll have the opportunity to select your command tracking speed, which deals with how sensitive your iPhone is to your various gestures and custom commands.
Case Issues
Your touch screen isn't the only place where your phone is sensitive to movements.
Your iPhone has a feature called a proximity sensor.
The role of the proximity sensor is to sense the closeness of your face during a phone call. When the phone senses that your face is close to the phone, it locks your screen to prevent you from accidentally activating the touch screen with your cheek or ear.
This is handy, except when the proximity sensor is partially obscured by a case and is no longer sensitive to the position of your face.
The proximity sensor is found on the upper right-hand corner of your screen, so ensure that it remains uncovered to preserve its sensitivity.
http://www.gadgetvenue.com/how-the-iphone-touch-screen-works-02223447/
http://www.appleinsider.com/articles/11/07/11/inside_apples_ios_5_assistive_touch_allows_accessible_gesture_commands/
Jul 14, 2013 • Cell Phones
2helpful
My icons are too big and i cant reduce the size???
Please follow this steps to set back the font size or icons of your Iphone.
* Tap the "Settings" menu from the iPhone home screen.
* Tap "Accessibility."
*Tap the word "Off" next to "Zoom" to turn the Zoom feature on.
*Return to the iPhone home screen.
Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
Thank you for visiting FixYa...
8helpful
3answers
Icon very big how can i make it small
First of all try this: Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
If it doesn't help, follow the steps below and repeat the above (step 5.)
  1. Tap the "Settings" menu from the iPhone home screen.
  2. Tap "Accessibility."
  3. Tap the word "Off" next to "Zoom" to turn the Zoom feature on.
  4. Return to the iPhone home screen.
  5. Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
6helpful
2answers
I was wiping my screen when all my home page icons became massive and now wont go back
This is one of the Accessibility features of the iOS. What you should do is tap on the screen using 3 fingers at the same time to zoom out to normal screen size.
To turn off that feature, go to Settings>General>Accessibility> Turn OFF Zoom or any of the other stuff in there if you don't need it.
For more iPhone / iPad / iPod touch tips like jailbreaking and unlocking, CLICK HERE.
3helpful
2answers
How do I enlarge my email screen
Place two of your fingers on the iPhone screen close together and enlarge your messages by sliding them away from each other. The farther you slide your fingers apart, the larger the letters/images will be.
You can also do this zoom-in motion while in Safari, Photo, or other apps.
To go back to normal size, just double-tap on the iPhone screen using any of your fingers.
Visit my blog for more iPhone / iPod touch tips. Also, view my other tips here in FixYa.
My fingers are not reading on the touch screen of iphone
i also have the same problem the second lines does not recognize my finger touch please give me solution
4helpful
How do I change the sensitivity to the screen so that I can use my longnails & not my finger?
you will not be able to use your fingernail on the hero screen. the touch screen is similar to the iphone (capacitive) and different to most other touch screens that use a stylus (resistive).
your finger is required for the screen to pick up where you touch.
there is a special stylus you can buy that will work, but make sure it is specifically for the iphone. a standard plastic tipped stylus will not work.
373helpful
2answers
My ipod screen is enlarged
Your iPod Touch is not broken! You accidentally invoked one of the accessibility features which zooms the screen. This happens when you double-tap the screen with three fingers simultaneously. To undo it, double-tap again and drag three fingers up or down.
You can turn this feature off by going to Settings > General > Accessibility > Zoom.
Top Eforcity Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an Eforcity Cell Phone Expert? Answer questions, earn points and help others
