SOURCE: HP Deskjet F4180 won't scan on my mac
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-55647-1&cc=us&lc=en&dlc=en&product=3177566&dlc=en&lang=en maybe it works !!!
SOURCE: HP PSC 1315, scanner and Mac os
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here : http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-41992-1&lc=en&dlc=en&cc=us&product=374572&os=219&lang=en
I just installed the software and am now scanning problem-free.
SOURCE: I have a HP C4480, I cannot scan and keep getting "scan failure"
Remove the printer to the trash. Disconnect and reconnect the printer. Everything will work fine.
Thanks
SOURCE: my Hp Deskjet F4200 series printer will not scan
Check to see that your Scanner drivers have been installed. Click on Start, then Printers and Faxes and see if a Scanner is listed. If not, you need to install the drivers.
Also, when you uninstall the printer drivers, you first need to disconnect the printer from the computer, and unplug the printer from the power source. Leave the printer unplugged for at least 15 minutes to clear the printer's cache memory.
Next, go to Add/Remove Programs in your Control Panel and uninstall the printer software. Then, turn off your computer.
Next, reboot your computer. Place the Deskjet cd in the drive and follow instructions for reinstalling the printer software and drivers.
CAUTION: DO NOT PLUG IN YOUR PRINTER CABLE TO YOUR COMPUTER UNTIL PROMPTED BY THE INSTALL DISK!!
SOURCE: I have a Mac OS X 10.6.4 & an HP Deskjet HP
I had the same problem, found out that you should not install the disk that came with the printer. If you do it won't scan. The drivers are already in Mac OSX. You have to uninstall whatever you installed...throw the disk away. To scan go to System Preferences, click printer, then scanner button and it works. Hope this helps!
