The first thing I check is the electric plug at the wall outlet to make sure I have 220 volts you will need a electric test meter If you are not comfortable with this you need to get a licensed electrician, with a ohm meter you can check the limit switches and the door switch with the power off at the breaker. one of the 110 circuits run the motor the other the element.
