I HAVE A 10 PHONE SYSTEM (PANASONIC KX-T7730 CORDED)
i whant them to ring diferent each phone, how can I do it?
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STCHANGING THE RINGTONE - img%20right%20hand.gifsrc="/uploads/images/img%20right%20hand.gif" alt="img%20right%20hand.gif" class="h_mi" /> The tone is now stored for that line on that phone only.
