Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Whirlpool Cabrio - How do I tell if my heating
Whirlpool Cabrio Dryer - How do I tell if my heating element needs to be replaced? There is no heat in the dryer.
    New Friend:
    Problem Solver:
  • 4 Answers
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Posted on Apr 17, 2010
2 Suggested Answers
SOURCE:
  • 38 Answers
SOURCE: I have no heat in my dryer. How can I tell if it
check for continuity on the heating elements leads.
Posted on Apr 16, 2010
Whirlpool cabrio dryer not heating
need to put a multimeter on ur thermal shut off fuse ur heating element and ur thermostats, u can buy inexpensive multimeters that will work just fine..
Jul 26, 2014 | Whirlpool WTW6400SW Cabrio Washer
I have a Cabrio dryer from whirlpool model # wgd6200swo and it will not heat up
Your dryers heating element has most likely gone bad. This typically doesnt occur unless the dryer has some age on it but it can happen. The heating element can be accessed from the back of the unit and is quite easly replaced if you are somewhat handy. SAFETY FIRST! Please make sure that you unplug the unit prior to attempting any repairs. Once you have disconnected the unit from its power source, you can begin to replace the heating element. You can usually purchase these elements at your local appliance store. Good luck.
Feb 08, 2011 | Whirlpool Dryers
Apr 16, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
Apr 08, 2010 | Whirlpool WED6200S Electric Dryer
Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Jul 24, 2009 | Whirlpool Dryers
The heat on our 2 year old Cabrio dryer just stopped working for no apparent reason. Everything but the heat appears to be functioning normally. Help!
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 18, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
1,170 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
