if it plays radio then youve hooked up the wrong amp turn on wire.you need to look at the back of the radio and make sure the blue with white stripe is hooked up.or the amp turn on not the ant turn on
Nothing went wrong but it require audio codecs to be installed your DVD drive must be having a CD with it which has nero burning softwares and other like nero show time and dvd codecs. Install this programe from the cd supplied with it. use power DVD etc. many softwares are there .dvd play back
yellow battery red accessory black ground purple right rear + speaker purple/black right rear - green left rear + green/black left rear - white fr left + white/black fr left - grey fr right + grey/black fr right - blue auto antenna blue/white rem amp brown phone mute orange/white illumination grass green handbrake but if u want to play dvd's whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
You have the wrong wire hooked up to turn on your amplifire. You used the blue wire but need to use the Blue/White wire!! That is an amp turn on wire Thje blue one is for a power antenna and goes dead when you put in a disc. The tweeters play because they are hooked direct to your Jensen. You'll be jamming in no time.
I have a 7in in dash dvd player but it does not want to play cds or dvds. it gives me an error notice. it won't even eject the cds. Where can I fix it?
Thanks
Try resetting the unit by pressing the small, recessed button on the faceplate with the tip of a pen. If this doesn't work, the player may be defective. There is no wiring error (including failure to hook up the parking brake input) that will prevent the unit from playing CDs.
you need a dvd player program that is designed for dvd playback I use Cyberlink powerdvd to play dvd's on my pc you could look for another player out there but windows needs a codec to play dvds with sound.
hope this solves your problem
