Tissot T33768881 Watch for Men Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Synchronize analog and digital time on Tissot T33 T-Touch Watch
How do i synchronize the analog and digital times on a tissot t33 t-touch watch ? There's no manual available for this watch !
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Apr 17, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1290904
Points
7081
I could not get any result from entering your model in their web site but the "T Touch online" seems to be a watch that has similar features perhaps.
Their catalogues seem to be generic, so by going to their web site http://support.tissot.ch/?mod_flashPDF/id_138 you may finswhat you need.
  • Watch4maker.com Oct 12, 2014
    Very easy level my friend.You activate the touch and touch the center until you see the opt.push the center button for 5 sec and you can see the synchro.with + or - put the hands at 12 o clock.push the middle button and you are ok.In my blog I have video how can you do that in sea touch.is almost the same.www.watch4maker.com
1helpful
3answers
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Tissot touch hour hand won't move
I’m in synchronization mode bur cannot move the hands
2answers
The digital time display and the hands display don't match
You can try to so the synchronization to match the digital time and the analog hands.
here are the step by step procedure including visuals, click on the link.
I hope this will resolve your issue.
Thank you for choosing Fixya.
3helpful
T-touch - Tissot is not synchronized
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals. Rate me, please..
Analog hands show 2hour 15minute ahead of the digital time. Can swap time zones fine, but the time difference remains. Cannot synchronize as per manual because cannot get eco-bat -1 set point. How to...
I have read the instructions and theyare as clear as mud!
If you haven't already tried it, try foll0wing the "local time" setting instructions, with reference to the s#last section "If necessary perform setting..............." This should either alter the hands or the digital display, so that you can get them to agree.
If you still cannot set your watch, then you might find it useful to go to Tissot.com and click on "contact us" and send them an email explaining your problem.
88helpful
2answers
Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
2helpful
2answers
Hi guys, my Tissot Touch watch has a non sinc problem with the digital and analog time. any solutions? thanks, Rodney
The Tissot Touch watch is expected to need "SYNCHRONIZTION" periodically. (that is, to synchronize the digital and analog portions.) The Tissot manual tells how to do this. This manual came with your watch and is available online from the Tissot website.
good luck, Rodney
133helpful
4answers
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
13helpful
2answers
Digital and analog display show different time
Paste this link into your browser:
http://www.t-touch.com/flash.html
1)Close available countries window,
2)Click on T-Touch, then choose Stainless Steel,
3)On the right side of the window click on film tab,
4)In the left box in the window find SYNCRO and click on it,
5)Watch and listen to instructions
6)Smile
Do not forget to rate, please.
1helpful
Tissot T-Touch-Works fine until just about the end of the warranty
I suggest writing to Tissot in both your home country and in the head office in Switzerland. Use both email and paper letters. If you can provide documentation of the attempted fixes that will really help your case. Since you had a history of problems you have every right to ask them to stand behind their product. Perhaps there is a new warranty on the replacement movement, for example. You have nothing to lose except a bit of time, paper and postage. You could even ask your dealer to back you up with this -- he or she will still get paid for the work if Tissot agrees to extend the warranty.
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
