Re: is there a way to transfer phone calls from this...
Yes, you should have a transfer button on the phone. click that then type the phones extension to which you which to transfer the call and hit transfer again
Your probably on a different ext. number now. If you were at location "A" ext. number 105 and you moved to location "B" that could be ext. 107. If you press your info button on the phone it will display your current ext. number.
To Program an ext. number on a button, simply press the Program button on display, select a button, type 1+ext number then enter. You can keep doing each button until they are all done, then press the exit button to back out of programming.
Chad first think is you need to enable your extension in comand #322
This is done on ext. 10 or 11
Press Feature 00
Left Intercom, Left Intercom
#322
Enter your extension number
Press 1 to assign
Feature 00
Next you will need to program your mobile number in speed dial
On extension 10 or 11
Press Feature 00
Feature 85
Input your mobile phone number
Next is to program a button on your phone
Go to your phone
Press Feature 00
Select a button to program (Press it)
Press Feature 11
dial 85
Done
Button works like a toggle switch on and off
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
sounds like the phone transfer numbering is out of sync or someone thinks its funny to send there transfered calls
i would go with the lessor of 2
phone numbering extensions example=
say you want to call someone at 2430 ext. but it takes you to 2340 that would be phone interupt extention box
the phone company who installed the software should come out and make sure the extensions are to the correct offices its there service but you pay for quality service to know and see it works
to send back calls just transfer back to secretary switch board the secretary will know what to do
