I am connect to the dish by HDMI 1 but it keeps reverting to the TV input. Happen when I connect to the other HDMI imputs also. Why?
I assume you are connecting a Dish Network receiver (model?) to your Sony TV with an HDMI cable. I also assume this happens daily. At a certain time (default 3AM but changeable) the Dish receiver (modern models) will reboot and the "screensaver" it normally outputs will be turned off for a minute or so. Some TVs, in obeying the rules for high definition connection (HDCP) will unlink their connection. Some are fussier than others and some will not automatically recover on power up. Since the Dish receiver must reboot to maintain its stability and then refresh its guide, you should be able to do this if the TV is turned off overnight.
If you still cannot get the connection maintained, I recommend that you connect with component cables--RGB+RW cables (the red-Y, the green Y=luminance, and blue-Y signals and audio right and left.) You may have to select a different input before turning the TV off, or maybe just changing source input will recover the one you want. I have no problems with my VIP722 receiver and my Samsung DLP TV. You might be able to get some more specific advice from the www.AVSforum.com message board for you TV.
-Ken
