Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
I am trying to obtain a manual for Krups Type 866
A very old model, possibly 15 years. Still works if only I knew how. A expresso and cappucino maker, similar in style to the 867
  • -jMu Nov 14, 2012
    I search for this manual too, but the given URL's in answers I could not entry. Maybe some-one can tell me how? thanks.
  • monasj Oct 18, 2010
    excellent..thank u vry much
4 Suggested Answers
SOURCE:
  • 4088 Answers
SOURCE: No power on the coffee maker/clock. Expresso side
Look for a defective heater, thermostat, safety thermal fuse, or a possible interconnecting wire is broken. This not considered a homeowner repair as it involves mains power and if the safety fuse blew, something made it fail. Because this is likely to be fairly expensive to repair (at a service shop), you should get an estimate and compare that to a new machine. Hope this helps!
Posted on Apr 12, 2010
Testimonial: "Good suggestions and right on. One of the thermal fuses was open. Thanks."
SOURCE: Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Posted on Aug 21, 2008
SpotBert
  • 231 Answers
SOURCE: I have an old expresso
Be advise on the recall of Krups. Just a sticker. Operation is fine.
http://www.cpsc.gov/cpscpub/prerel/prhtml95/95051.html
Posted on Dec 26, 2008
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Jul 27, 2015 | Rancilio SILVIA EXPRESSO MACHINE Silvia...
I bought a Krups 867-42 espresso cappucino maker from a second hand store. I need instructions on how to make espresso and how to froth milk. I have the necessary coffee pot to brew regular coffee, but...
Hi austyn90211,
Welcome to fixya!
Here is the user's guide to your espresso machine: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035208.pdf
Enjoy!
Handie Andie
Jul 15, 2011 | Vacuums
Apr 12, 2010 | Krups Caffe Bistro 867 Espresso & Coffee...
No water coming out of the group head?
Your problem is either the brew solenoid or the brew switch.
Feb 09, 2009 | La Marzocco FB-80 Series 3 Groups Coffee...
Cafe Roma Expresso/Cappucino machine
My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
Leaking water from the group and steam spout
You will need to take the machine apart completely as there are more gaskets inside the group head. You can buy an old group service kit at www.theespressoshop.co.uk for about £20 and it comes with an exploded diagram so you can see what goes where. Don't worry there is no technical mechanical solenoid like the last comment stated. I repair these machines for a living and all it needs is a good service.
All the best
LaPavoniBoy
Nov 13, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Are there any published example beverage settings for Saeco 8p expresso vendings Eg, Recipe for cappucino & latte
what kind of recipe do you want to know.Cappuccino is Made from Latte and Coffe.Sturbucks is not Cappuccino..Originally the name cappuccino came from COFFE(BLACK) AND MILK(WHITE).Both togheter give the color called CAPPUCCINO.In so many years the cappuccino found different way to make it work....caramel,coccoa,nutmeg....The good recipe and famus still the regula cappuccino with sweet or unsweet coccoa on the top of the foam.
Apr 19, 2008 | Saeco Incanto Classic Espresso Machine
Espresso side
Hi. Was searching around and you can actually go to the krups website(www.krupsusa.com) and download the appropriate manual for your coffemaker. Its best to know the model number as well as the model name. On the Bistro, the coffee maker side should be on the left and the expresso side on the right. on top of the coffee maker on the right side is a screw on top(black in color depending on year of model). Simply unscrew and fill with water to recommended lvl. I would download the instructions first and become familiar with the process as it heats up the water to extremely high pressure and heat. Good luck..J
Oct 28, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Open Questions:
See all Krups Caffe Bistro 867 Espresso & Coffee Maker Questions
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
2,309 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
