what you need to do sir is take your carb off clen it rebiuld it and did you do a compression test? must have a min of 120 to 160 compression anything eles is failure.what you need to do sir is take your carb off clen it rebiuld it and did you do a compression test? must have a min of 120 to 160 compression anything eles is failure.
You can't post conmments that contain an email address.
Mine was NEW last year.. sat all winter with STABIL added to gas.. Now cranks but won't run... Plug looks like it is flooded. Will adding some DRY GAS & letting it sit a day do it?Mine was NEW last year.. sat all winter with STABIL added to gas.. Now cranks but won't run... Plug looks like it is flooded. Will adding some DRY GAS & letting it sit a day do it?
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
If the starter motor is actually turning the engine then the first thing to do is check the spark plug to see if you are actually getting a spark. If there is a spark, then move on to the fuel system to eliminate restrictions in the flow. The problem could be due to a dirty fuel filter, faulty fuel pump or solenoid fuel valve, no voltage on valve or dirt in the float bowl or a blocked float valve. Have a look at these tips for troubleshooting lawnmower starting problems. They apply to tractors also:
Unless you have a diesel, the black smoke at start up is not normal, it should be white if anything. It sounds like you are burning very rich, or no air at all, check the air filter, check the fuel cond, check the governor thing, make sure it moves freely and rebounds. Change the spark plug. I don't know what else it could be without being there. The carb could be clogged up, some carb cleaner wouldn't hurt. Hope this helps.
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
