Nokia N73 Music Edition Smartphone Logo
Posted on Apr 16, 2010
Nokia N73 signal problems
Hi, i have a Nokia N73 and i dropped it last night. Since then, the signal has just been dropping and coming back. Right now the signal is on but I cant connect to the internet even though it is set to 'When Available'. I have all the right settings. Help me please.
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Apr 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
1685
Points
42
Network is dmaged go to mobile phone repaier place and fix it will cost 30 to $40
My nokia n73 kepads 5, 7, and 9 not working. what should i do?
Hi, what makes 5,7,9, numbers not working,is because the IC chip inside the phone board that makes the numbers work is damaged. Might be caused by water , liquid substance, or phone dropping on the phone.
To solve this problem, you will need to replace the IC chip inside the phone board. You will need an expert for help on this matter. in other not to damage the phone more.
Hope it helped.
Thanks for using fixya....
4helpful
Signals dropping, calls dropping, voice receiving
Sanyo fones have had this problem for all of their cdma devices.If yuo twist the outside of the fone, & the service comes back to the device,we have found this 2 be a manufacturing defect,w/ the device.JP Sprint PCS since 07/1997.But,I choose Sanyo,over all the rest!
4helpful
4answers
Nokia 6310i - Low and No signal
It's possible that you could fix it, but not entirely likely. It depends on whether it's just a bent antenna connector or if a circuit board is broken.
Some phones have a small spring-type piece that makes contact with the antenna. If this is merely bent, and not making a great connection, you might be able to coax it back into shape and that might fix your phone. Otherwise, it's probably beyond the ability of an amateur to repair.
Nov 06, 2009 • Nokia 6310i
My nokia N72 was dropped in water i immediately
Have it taken to a technician and ask if you can have it cleaned with an CRC Electronic cleaner availiable at any hardware store.
Even better if you have a precision tool set. DYI. clean with a toothbrush.
1helpful
HI, I have a Nokia N73.The phone keeps scrolling up and down by itself and I am unable to call people or text them due this issue.This is happening since last night.Tried to do a master reset but have...
turn fone off take battery off,then put back in and turn it off,then go to menu settings find master reset and click that and will be like new.if my info was of any help to you please leave a comment,note,vote.thnk you
NOKIA N73 DROP IN WATER,BUT FRONT CAM.NOT WORKING
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
N73
its coz of the battery is over heated.. u shdnt charge a cell for a full night.. its not advisable.. u better change the battery else contact a service center.. else.. u wait for 1 or 2 days.. and then switch it on.. sometimes it may work!!
17helpful
5answers
Wall Paper in full screen
Hi, I am using Nokia N73 music edition. I want to know Can we have Wall papers to come as full screen when applied as the wall papers, instead of what it comes as i.e, in standard size.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
